You can inspect changes to a script in the following ways:
Expand the Change Log panel by clicking its
 button. This displays the list of changes.
The illustration below shows that the user's active script was created from version 2 of the script "Main IVR" and, since loading the script, the user has made changes to the script's action cells, variables, and counters.
The following information is displayed:
           Category  |
           Description  |
           <creation information>  |
           The first line in the log indicates whether the script is:
           Action Cells  |
           Click an 'Added', 'Updated', or 'Deleted' item to see a detailed breakdown of the change.
           Variables  |
           Click an 'Added', 'Updated', or 'Deleted' item to see a detailed breakdown of changed values.
           Counters  |
           Click an 'Added', 'Updated', or 'Deleted' item to see a detailed breakdown of changed behaviour.
Note: the Action Cells, Variables, and Counters sections of the change log are reset when you commit a script but not when you save it.
Select the LOAD SCRIPT command from the menu at the top right of the screen.
Select the saved or committed script whose change information you want to see. (A committed script is always tagged with a version number.)
Expand the Action Cells, Variables, or Counters item to see any changes for these items.
The illustration below shows that version 4 of the script 'Monumental IVR' was created from version 3 of the same script. Action cells were added, updated, and deleted between the two versions.
